5 members (rfs56trk, Gib70, Lightholder's Dad, Gray_Ghost, 1 invisible), 134 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
#607768 01/07/2010 12:30 AM
Here's an easy one for ya; which post on the fuel gauge runs to the tank? One of the posts has what's left of a red tag that said 'warning' or maybe 'caution', I don't remember now. I need to get my fuel gauge hooked up and don't want to fry it in the process. Thanks
Oh yeah.. I've swithed the truck to negative ground if that changes any thing.
twotone #607775 01/07/2010 12:48 AM
1 Offline
Originally Posted by truckernix
Well, there are two studs and the frame is grounded to the dash. The power stud supplies the power to one movement coil directly and suppies power through a second coil to the sender. So, measuring the resistance to the unit frame from each stud separately should give two dufferent values. The one giving lower resistance value is the power lead.
TwoTone, If i remember correctly, The red tab stud goes to the sending unit. Do a little checking with your gauge and use what Truckernix said in a prior post.
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
1 Offline
TwoTone, I confirmed with PapaJ that the red tab stud goes to the sending unit.
Jeremy
Thanks Jeremy. That's exactly what I needed to know.
