0 members (),
87
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 20 New Guy | | New Guy Joined: Dec 2009 Posts: 20 | Any one wise to how new a steering wheel I can put on my stock '52 GMC? I saw some early cool ones from '90's GM...but I don't know if the splines are the same? Any Help? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | welcome to the bolt. I doubt if swapping the wheel will work. You will need to replace the column as well to get a new wheel. For information on this you might check the archives here. Good luck and happy new year.
~Jim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I currently have a 50's wheel on a late 70's column setting out in my shop. It proves the splines match at least that far.
In the 90's steering wheels started including an air bag and I don't think you want to adapt one of those.
Another approach might be to swap wheel and column together.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | GM used the same spline on the AD Trucks as they did up into the 90's and 2000's. The spine on the earlier wheel is buried back further in the center of the wheel. So that might be a problem. Have you converted this truck to power steering, without it the smaller wheel is gonna be a PITA. Mongo | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | GM used the same spline on the AD Trucks as they did up into the 90's and 2000's. The spine on the earlier wheel is buried back further in the center of the wheel. So that might be a problem. Have you converted this truck to power steering, without it the smaller wheel is gonna be a PITA. Mongo PITA is an understatement. You better starting working out if you decide to go that way.
~Jim
| | | | | Joined: Dec 2009 Posts: 20 New Guy | | New Guy Joined: Dec 2009 Posts: 20 | Thanks for the info...Power steering is my goal. I love the truck and I don't want to hate driving it........ | | |
