3 members (Ponchogl, ShopRag, 52hornsby), 81 guests, and 2 robots.
Topics128,035
Posts1,055,564
#606937 01/04/2010 3:28 AM
Hey Guys,
I'm installing my 327,w/300 D hump heads and no bracket holes into my '48 and now I am wondering what ALT,PS,brackets do I use on my motor.
Anybody have this problem if so do you have any pics of what you did or what brackets you used?
Thanx
You'll need brackets from a mid-1960's engine, before they started using the heads with bolt holes in them. As I remember it, the driver's side exhaust manifold had bolt holes for the alternator bracket, and other accessory brackets mounted to the intake manifold and/or the front engine mount holes down near the harmonic balancer.
If all else fails,go to your local hotrod shop and purchase the Alan Grove brackets.They work like a charm.
dale937 #607195 01/05/2010 12:37 AM
I use to have a 1966 c20 with original 327.The exhaust manifolds were called long horns.The drivers side had provisions for the alternator bracket.
1951 3100 Chevrolet
bowtietim #607223 01/05/2010 2:20 AM
Close bowtietim.....Ramhorns, thumbs_up
Thanx guys but I forgot to tell you that
I am using shorty blockhugger headers.
back up and punt? headscratch
Hey dale937,
Thanx for the heads up on the Alan Grove Brkts. they have a great product.
mike
Camel-hump heads (64 CC) aren't all they're cracked up to be. I use the late model low-compression heads with the bolt holes, and angle-mill them to get more compression (60 CC) than a camel hump. They're also "legal" for claimer engines if the tech man doesn't know what to look for!
Thanx Hotrod Lincoln,
but I have all the head work (3 angle, seats,seals) ready to go
and installed just tring to get the right brackets.
Mike
bill's hot rod brackets are very nice, work great for this. have a set on mine. very reasonable also.
Thanx barnescole,
Ill give them a try.
