0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#606197 01/01/2010 7:53 PM
1 Offline
Any one wise to how new a steering wheel I can put on my stock '52 GMC? I saw some early cool ones from '90's GM...but I don't know if the splines are the same? Any Help?
12181955 #607391 01/05/2010 6:48 PM
welcome to the bolt. I doubt if swapping the wheel will work. You will need to replace the column as well to get a new wheel. For information on this you might check the archives here. Good luck and happy new year.
~Jim
BIG CHEVY 3600 #607396 01/05/2010 7:09 PM
I currently have a 50's wheel on a late 70's column setting out in my shop. It proves the splines match at least that far.
In the 90's steering wheels started including an air bag and I don't think you want to adapt one of those.
Another approach might be to swap wheel and column together.
OldSub #607402 01/05/2010 7:29 PM
"MONGO"
"MONGO"
GM used the same spline on the AD Trucks as they did up into the 90's and 2000's. The spine on the earlier wheel is buried back further in the center of the wheel. So that might be a problem. Have you converted this truck to power steering, without it the smaller wheel is gonna be a PITA.
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
KCMongo #607594 01/06/2010 6:49 AM
Mongo
PITA is an understatement. You better starting working out if you decide to go that way.
~Jim
BIG CHEVY 3600 #607880 01/07/2010 12:14 PM
1 Offline
Thanks for the info...Power steering is my goal. I love the truck and I don't want to hate driving it........
