1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | [IMG] http://i47.tinypic.com/34zluyx.jpg[/IMG] talking about the the pipe type piece with the pinched end. just wondering what this is for. i accidentally broke this off and was gonna put this plate on my 235 from my 216 and was wondering if i would be ok running without it. any help appreciated.thanks ahead of time. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are referring to the post with a slot in the top, I think it directs lubrication oil to the gears. I'll check a manual and revise this post. You might be referring to the Timing Gear Oil Nozzle. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It's a lubricator for the timing gears. It screws into the end of the oil passage in the block. It has a small hole drilled in the side so the oil squirts onto the gears. No, it's not a good idea to run without it! Jerry
| | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | [censored] , so i need to get a new plate? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If your part is the one referred-ton in the manual, the manual suggests replacing the plate if the nozzle is damaged.
| | | | | Joined: Jun 2009 Posts: 17 Apprentice | | Apprentice Joined: Jun 2009 Posts: 17 | dam, anyone got one cheap? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It's not that hard to replace. If you can't find another plate, send me yours and I'll fix it. Jerry
| | | | | Joined: Apr 2009 Posts: 29 New Guy | | New Guy Joined: Apr 2009 Posts: 29 | I have a 216 block in my brother in laws garage that I don't intend to use. I'm about 45 to 60 minutes from Janesville in Illinois. give me a call we could probably remove it from mine if you still need one Scott cell # 847-951-3720 | | |
