| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | Could you please help me ID my (2) 235's ? (at least I think they are)
The first set of block numbers are: CON 3 G98 (behind the starter) 3738307 (near the distributor) I think this is a 1958 235
The second engine I have is: CON 3 F229 (behind the starter)3764476 (near the distributor) I have no clue the orgin of this engine
Any help you guys can offer would of great help!
Thanks, | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | G98 G = 7 = July 9 = 8th day 8 = 1958 3738307 = 58-60 (and, maybe later) passenger car block??
F229 F = 6 = June 22 = 22nd day 9 = 1959 3764476 = 56-62 truck block??
The question marks just mean that the information came from the Internet, not from a GM manual.
| | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | Wow, that was quick! Thanks for the help! | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | Not sure if this is true for all years, maybe some others can expand onthers can expand on this. There should also be numbers stamped on the pad just aft of the distributor. These should tell you the engine assembly plant (F for Flint and T for Tonawonda), the engine assembly month and day, and the use.
IE: my '57 car engine is T1026FC
T= Tonawonda 10 = Oct 26 = 26th FC = 4 barrel w/powerglide
Since the block casting date was 56, I know this engine was assembled 26 Oct 1956.
Joe D. | | |
