1 members (Gdads51), 57 guests, and 1 robot.
Topics128,056
Posts1,055,799
#606901 01/04/2010 2:34 AM
Apprentice
Apprentice
[IMG]http://i47.tinypic.com/34zluyx.jpg[/IMG]
talking about the the pipe type piece with the pinched end.
just wondering what this is for. i accidentally broke this off and was gonna put this plate on my 235 from my 216 and was wondering if i would be ok running without it. any help appreciated.thanks ahead of time.
If you are referring to the post with a slot in the top, I think it directs lubrication oil to the gears. I'll check a manual and revise this post.
You might be referring to the Timing Gear Oil Nozzle.
It's a lubricator for the timing gears. It screws into the end of the oil passage in the block. It has a small hole drilled in the side so the oil squirts onto the gears. No, it's not a good idea to run without it!
Apprentice
Apprentice
[censored] , so i need to get a new plate?
If your part is the one referred-ton in the manual, the manual suggests replacing the plate if the nozzle is damaged.
Apprentice
Apprentice
dam, anyone got one cheap?
It's not that hard to replace. If you can't find another plate, send me yours and I'll fix it.
I have a 216 block in my brother in laws garage that I don't intend to use. I'm about 45 to 60 minutes from Janesville in Illinois. give me a call we could probably remove it from mine if you still need one Scott cell # 847-951-3720
