0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#606901 01/04/2010 2:34 AM
Apprentice
Apprentice
[IMG]http://i47.tinypic.com/34zluyx.jpg[/IMG]
talking about the the pipe type piece with the pinched end.
just wondering what this is for. i accidentally broke this off and was gonna put this plate on my 235 from my 216 and was wondering if i would be ok running without it. any help appreciated.thanks ahead of time.
If you are referring to the post with a slot in the top, I think it directs lubrication oil to the gears. I'll check a manual and revise this post.
You might be referring to the Timing Gear Oil Nozzle.
H Online: Content
It's a lubricator for the timing gears. It screws into the end of the oil passage in the block. It has a small hole drilled in the side so the oil squirts onto the gears. No, it's not a good idea to run without it!
Apprentice
Apprentice
[censored] , so i need to get a new plate?
If your part is the one referred-ton in the manual, the manual suggests replacing the plate if the nozzle is damaged.
Apprentice
Apprentice
dam, anyone got one cheap?
H Online: Content
It's not that hard to replace. If you can't find another plate, send me yours and I'll fix it.
I have a 216 block in my brother in laws garage that I don't intend to use. I'm about 45 to 60 minutes from Janesville in Illinois. give me a call we could probably remove it from mine if you still need one Scott cell # 847-951-3720
