| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I just purchased a new speedometer cable for my '48 because the old one is binding, plus it has a plastic cover and I wanted to get a more correct metal one. My question is this. Should the cable be lubricated, and if so, with what? | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | It should be lubricated. Years ago you could buy just the cable without the housing (and use your old housing)and it came with a little tube of grease. Samantha | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I used to use a graphite suspended in a solvent base. It was called dripless oil or something like that.
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Ask whoever sold the cable to you. A new cable is usually ready to use (ie lubricated) whether custom-made or off the shelf. It is recommended not to lubricate a speedo cable, what you will squirt/spray in there may interfere with what is already in the housing, or cause more problem than anything.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | AC made (or maybe still does make) a grease especially for speedometer/mechanical tach cables. It is pretty thin grease like Mystic jt-8. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | White Lithium Grease is what I use... | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Wave, I got the cable from Jim Carter, and it's not lubricated.
Since I live in the Northeast, and I take the truck out from time to time in the winter, I'm concerned that whatever I put in there might freeze, or at least thicken enough to cause problems.
White Lithium sounds like a good idea. Maybe I'll take a trip to a FLAPS to see what they have. | | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | When my '56 GMC 3/4 ton was on the road in the early 80's, the previous owners or their mechanics must have greased the speedo cable with something thick. It worked fine except initially in subzero temperatures, when it would alternate between not reading anything then fluctuating wildly towards the top of the scale. It would do that for a while, then settle down to working. I assume the spring wound up enough to overcome the resistance of the cold thickened grease. Then I thought it a funny quirk, now as I am readying it for the road again, I will try to clean that grease out, 'cause I want it to keep working. Anyone else have the crazy needle syndrome?
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Lithium works
I agree about the plastic housing. I had to really work with mine to make it work- the plastic one was not the same length and the hookup was slightly dofferent. I couldnt use the old housing because it has a tear in it and I couldnt put the new cable inside the old housing due to lenght. But it is done and working. I am looking on e-bay for the actual replacement though because I want it to be more original.
| | | | | Joined: Nov 2008 Posts: 48 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 48 | Anyone else have the crazy needle syndrome? My '58 does it, and it rarely freezes here in south Texas.
Sometimes you got to leave 'em like you found 'em.
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I would go with the graphite power,first off because it's a powder and it won't bind up your cable like grease or oil will in colder tempratures. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | The Crazy Needle Syndrome (CNS)  is what made me buy a new cable. I was afraid the speedometer itself would be damaged. As time goes on, the needle gets crazier and crazier, by the way. In my case, it happens in warmer weather, too, but not as much. | | |
