4 members (Chip O, Otto Skorzeny, Wayne67vert, fonz8261), 51 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
#606773 01/03/2010 7:55 PM
I just pulled the 216 out of my 40 PU. I plan on putting in a 235 I have. After removing the clutch & pressure plate, I started wondering why the bell housing doesn't have all bolts accesable from the outside? You have to fight taking the clutch & pressure plate out and remove the flywheel just to get to the bolts on the bellhousing. I need to bellhousing to make the swap and have to take everything apart just to get the bellhousing. I probably will reuse the clutch & pressure plate, though, because they are new. It would be easier with the bellhousing off first. Just whining a little, I guess.
H Online: Content
That's just the way they're designed, clutch & flywheel off first, then remove the bellhousing bolts trapped behind the flywheel. Be glad the crankshaft isn't locked up where the pressure plate bolts aren't accessible!
Try taking a bellhousing off one that had water in the motor for 40 years,it took me a couple saturdays to get it off and its a good thing swivel sockers are made.
