5 members (Jon G, Hotrod Lincoln, Otto Skorzeny, BC59, 46truck), 109 guests, and 3 robots.
Topics128,122
Posts1,056,331
Members48,439
#606606 01/03/2010 1:52 AM
I am running a 1956 ( I think) 235 in my 1953 3100. I have a couple of oil bath air cleaners that don't fit on the carb. ID of air cleaner is about 2", OD of carb on engine is about 2 3/8" with a ridge or ring around the top. Is there a carb that I can put on the 235 that will accept the oil bath ? Is there an adaptor that I can put on the present carb to accept the oil bath? The little chrome paper filter I'm using now looks lousy. Thanks
jdl Offline
Well, what kind of carb do you have to start with? I've got a Carter(YF model???, been a long time since I looked at the carb) on mine with an oil bath air cleaner, but I though Rochesters worked with them too. Someone should come along shortly with more info.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Ex Hall Monitor
Ex Hall Monitor
Posting links to a few pics would help the sleuths around here to help you Paul.
