| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | I am running a 1956 ( I think) 235 in my 1953 3100. I have a couple of oil bath air cleaners that don't fit on the carb. ID of air cleaner is about 2", OD of carb on engine is about 2 3/8" with a ridge or ring around the top. Is there a carb that I can put on the 235 that will accept the oil bath ? Is there an adaptor that I can put on the present carb to accept the oil bath? The little chrome paper filter I'm using now looks lousy. Thanks | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, what kind of carb do you have to start with? I've got a Carter(YF model???, been a long time since I looked at the carb) on mine with an oil bath air cleaner, but I though Rochesters worked with them too. Someone should come along shortly with more info. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Posting links to a few pics would help the sleuths around here to help you Paul.
