| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I pulled the yoke in preparation to change the pinion seal. I had a slow leak that was I was tired of. Unfortunately, I found a groove on the yoke. Picture: http://i50.tinypic.com/357frjq.jpgAm I right in assuming that that grove would allow the gear oil to leak out? The pinion seal appears to be in good shape, so I don't think that is to blame. Pinion seal: http://i50.tinypic.com/wahi83.jpgWhat would have caused that groove to form in the first place? | | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Measure the diameter of the flange and get a speedi-sleeve for it. Most bearing supply places can provide a thin stainless repair sleeve to cover the groove, and the same size seal can be used. Always install a new seal whenever the relationship is disturbed. Jerry
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | What would have caused the groove in the first place? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The groove comes from years of rubbing. All yokes have a groove to some degree. That is why in the last 20 years or so seals have been developed that seal within themselves. They no longer rub on the yoke. | | |
