6 members (Barry Martak, Otto Skorzeny, Hawkman, stlcardinalsguy, MickeyP, Oswald), 113 guests, and 2 robots.
Topics128,088
Posts1,056,414
Members48,443
#606193 01/01/2010 7:28 PM
My 62 1/2 ton Chevy truck needs bigger tires on the rear to help lower RPMS. I have a 235 c.i. six with a 390 rear end. Presently have 235/70/15 tires. How large can I go without a problem? I have a three speed three-on-the tree trans. Thanks for any information.
Green Machine
Edabbs #606363 01/02/2010 3:30 AM
I've put 32x11.50s on them before without issue. You will need wider wheels, though (8-9").
Bill Burmeister
LONGBOX55 #606391 01/02/2010 4:59 AM
I went from 235/75R/15's to 265/75R/15's on the back of my '72 C-10. It made a notice-able difference. They look good too.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Edabbs #606459 01/02/2010 3:46 PM
Might I suggest you use a calculator to pick which diameter gets you into the RPM range your engine likes?
http://www.ringpinion.com/Calc_RPM.aspx
As an example:
With your current set-up you are turning 2574 RPM at 55 mph
Change to a 32 inch diamter tire and you will be turning 2252 RPM at 55 mph.
Keep in mind that if you go too big you will affect your launch ratio, which simply means you will have to slip the clutch to get going.
Thanks for the replies to my question! I previously ran a three speed borg warner overdrive trans but it needed an overhaul-kept jumping out of high gear so I put the regular three speed back in. Rather than spend a lot on the overdrive thought I would try larger tires first. Sure miss those higher gears. Any other suggestions are appreciated.
Green Machine
