| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Wow! One piece curved wiindshield. Problems,problems, can't get the weatherstrip & stainless trim to fit over the windshield properly. I've got the rubber from my third supplier, this one (from Counterpart Automotive) does go on but doesn't fit properly in the corners. The others (from Thailand) stretched so tight and distored that they would not go on. Has anyone done this on a '54 successfully. I've read many stories on different forums telling of all the problems even with auto glass installers doing the work. Going crazy in Kansas. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The feneral response is that these people make the best quality rubber parts. They are more expensive but fit best. https://secure.steelerubber.com/ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I've installed several 54/55 windshields and have had problems most of those time.
1. Greg's advice is excellent. 2. If you have an original windshield, you should then have no problem. 3. Repro 54/55 windshields might have bends that are slightly-off and will cause difficulties. 4. Repro 54/55 windshields might be slightly larger that originals (if patterns were made from existing windshields to make the repos (rather than using original patterns) - each incremental pattern might be a tad larger than the original).
This summer, I hope to be installing a NOS 54/55 windshield with the stainless trim and with a Steele seal. I'll post my experience at that time (sorry this is of no use to you at this time).
| | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | I keep hearing that Steele is the best though a bit pricy. I looked at their site and talked with them about there weatherstrip. They make it right there at their plant and it is guaranteed.
I'm going to mess around with one from CounterParts a bit more. It fits on the windshield well at the first end but not the last end that went on. That's telling me I didn't quite get it right.
I appreciate the help. Don | | |
