1 members (Cosmo), 86 guests, and 0 robots.
Topics128,049
Posts1,055,680
#605994 01/01/2010 3:47 AM
U
U Offline
Hi,
I have a 235 engine on my 1957 Chevy.
I am unable to find the mounting bolts for under the generator. Can someone tell me if the 2 bolts mounting the generator are of special strength? Looks like according to the manualv(RPO 329 SHEET 3.00) the original had a nut with a cotter key. Would the end of the bolt have a hole as well for the key? Thanks for any help!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
Mine has two simple bolts with nuts that create friction on the thread. I think nylock nuts would do the same thing. If you just tighten them then the generator can't swing on the hinge.
1951 1 Ton Completed
U
U Offline
Hi Truck,
Good thought. The nylock would work great. I will give it a shot.
Jon
More pix
Ok my brothers, replying to "look" in a salvage yard is not the holy Grail for us newbies. I have my 235 with rear bearing seal all buttoned up. The "millions" of S 10 / T 5 transmissions ( 82-92). Took months to find . The suggested replacement 14 spline clutch for a 1983 firebird may fit the T5 but the pressure plate does not fit the flywheel bolt pattern. Where am I going wrong here ?
WisApache,
you are going wrong by asking your question in this thread. You need to start a new topic.
Mine has lock washers.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Apprentice
Apprentice
mine has 2 fine thread 1.25 inch bolts with lock washers
U
U Offline
Hi all,
Thank you for the support...Sorry to ask so many questions just missing alot of old bolts and want to do the job right ...the first time..
Jon
More pix
We're all missing bolts,nuts,and lost marbles.
1953 Chevy Two-Ton
U
U Offline
HA!
Amen!
More pix
