5 members (3800GUY, FAST55, wilbur53, Jon G, Otto Skorzeny), 190 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#60574 05/17/2006 8:48 PM
Anyone done this to an AD? I want to know if I need to buy van wheels for the front?
jay
Your lack of preparation is not my emergency
#60575 05/17/2006 10:18 PM
the kit comes with 5 on 4-3/4" lug pattern wheels. so its probably a camaro rotor so whatever wheels would fit a camaro would work for this kit. good luck
#60576 05/17/2006 10:20 PM
#60577 05/17/2006 10:21 PM
I've got the kit- It is 70-77 Camaro rotors and calipers= works nicely!
Don't forget to upgrade the wheel bearings at the same time. I don't think they're included in the kit.
#60578 05/17/2006 10:35 PM
I didn't buy the full kit, just the rotor brackets, basically. I think I got all the bearings in there too, but will check. I know it's the camaro/malibu bolt pattern, but will anything get in the way of the wheel? Is there any way to test after the conversion without putting on a van wheel? Thanks for all the help.
#60579 05/17/2006 10:41 PM
All Chevrolet car after '49 have the 5 on 4 3/4"
bolt pattern exept for police/taxi Caprices and
SS Impalas from the mid '80's and up. S-10 2wd's also have the same bolt pattern. Just letting you know, you can most likely get the wheels for less if you look for caprice wheels instead of camaro wheels.
Bill Burmeister
