1 members (Ponchogl),
163
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60574 05/17/2006 8:48 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Anyone done this to an AD? I want to know if I need to buy van wheels for the front?
jay
Your lack of preparation is not my emergency
#60575 05/17/2006 10:18 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | the kit comes with 5 on 4-3/4" lug pattern wheels. so its probably a camaro rotor so whatever wheels would fit a camaro would work for this kit. good luck | | |
#60576 05/17/2006 10:20 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | | | |
#60577 05/17/2006 10:21 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I've got the kit- It is 70-77 Camaro rotors and calipers= works nicely!
Don't forget to upgrade the wheel bearings at the same time. I don't think they're included in the kit.
#60578 05/17/2006 10:35 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I didn't buy the full kit, just the rotor brackets, basically. I think I got all the bearings in there too, but will check. I know it's the camaro/malibu bolt pattern, but will anything get in the way of the wheel? Is there any way to test after the conversion without putting on a van wheel? Thanks for all the help.
#60579 05/17/2006 10:41 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All Chevrolet car after '49 have the 5 on 4 3/4" bolt pattern exept for police/taxi Caprices and SS Impalas from the mid '80's and up. S-10 2wd's also have the same bolt pattern. Just letting you know, you can most likely get the wheels for less if you look for caprice wheels instead of camaro wheels.
Bill Burmeister | | |
