0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Silly Jimmy question time:
Is a '50 GMC 228 a pressure-oiled engine, or a babbitt bearing splasher?
I've got a line on a cool old '50 GMC 1/2-ton with this engine. It is absolutely bone-stock! Pros/cons???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The GMCs are all full pressure.
Bill Burmeister | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Great! Next Q - what rear axle ratio is this likely to have?
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | there are no cons all pros. most likely 4:11 | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | That's what I figured. Looking at a truck in KS, and I might have a swap deal worked out. I'll post some pics and such if the deal actually transpires!
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Well, the trade deal did not work out on this '50 GMC, but if Uncle Sam doesn't rake me over the coals on taxes this year, maybe I can do a cash deal, instead. Hate spending money around tax time, because inevitably, I owe the bastards.
