0 members (), 186 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#605617 12/30/2009 11:59 PM
I bough a seat from a junk yard in OK, which found me when I posted on UsedPartsCentral.com. The seat came and will need to be reupholstered as expected. While the bolt holes look like they'll fit just right, the seat construction is completely different and looks like I'll be riding almost 4 inches lower. Should I be concerned about this?
Thanks for the replies.
I wouldn't be worried.
If necessary, you can adjust the seat height by "blocking it" using square tube or similar.
You can even cut down 2" X 4"'s and use long bolts if you're short on cash. smile
I thought about blocking it, that would work. I was just surprised about overall condition and difference. My old seat, besides three broken springs, has no rust and looks really good, now that all the upholstery is off. The seat sent to me apparently spent some time on the ground, the edges are really rusty and sharp. Sharp enough to tear through any new fabric. I paid 200 for it and for that I think I shouldn't have to do so much grinding and welding.
Sounds like it wasn't a very good deal. Will they take it back ? If not are the springs the same. Id replace the three broken springs from there seat if they wont take it back and go from there. That way you don't have to block up seat. Tom
Moderated by  ndkid275, Phak1
