6 members (MRMEROTH11, cmayna, David Bush, Hanks custodian, walter74, 1 invisible), 53 guests, and 3 robots.
Topics128,056
Posts1,055,800
#605341 12/29/2009 11:54 PM
Hi all,
a friend of mine bought a 1957 4100 (1.5 ton)chevy. I went out to take a gander at it and noticed it had 22.5 tubeless tires and wheels on it all around. The odd thing was that the front wheels had 6 lugs and the back duels had 10 lugs. Is this normal or would you think someone has done some switching of axels over the years?
Your thoughts are appreciated.
Harrydale
It's the same way on my 1954 and 1955 1st Series COE's.
Bruce
My Trucks
Stuff I Collect
My guess is it has a 2 ton front axle to get the 6 lug Budd wheels, and rear is likely original 1.5 ton.
Tubeless wheels were standard in 56, although many ordered the familiar 20" tube type.
If you run across any more of those 22.5" wheels with 10 lug on 7.25" circle I'm always looking for some.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
is there a way to ID whether it is a 1.5 or 2 ton front axle?
Harrydale
Brake size?
I'm not so familiar with the later axles.
but for a 48-53 1.5 ton axle it has press in hub grease covers, and the 2 ton has covers held on with about 5 small bolts. I don't know if this holds true for the later axles.
But so far as I can tell 56-59 1.5 ton axles are 5/10 lug, and 2 ton is 6 lug Budd.
Some parts manual searching will probably reveal the truth.
Grigg
---All pictures---
I don't know about the TF trucks but on AD trucks the 2-ton axle is physically bigger in several dimensions. The 2-ton front axle was an option on the 1-1/2 ton trucks though.
Check the Restoration Pack for the dimensions.
3B Offline
Hy guys, the 1 1/2 ton axles I am used to, from the late 40s to the mid 50s have an eight sided end and are screwed into the hub with a very fine right hand thread, and the 2 ton bearing cap is bolted into the hub and has a dome shape to it, hope that helps.
3B #605445 12/30/2009 4:47 AM
thanks for the info guys.It will help a lot. I will go out and take another look at it to see if I can determine what the front axle is for sure.
Grigg, I will keep you in mind if he decides to change out the wheels for some reason.
Harrydale
