7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost), 102 guests, and 15 robots.
Topics128,077
Posts1,056,033
Members48,433
#60527 05/15/2006 5:02 PM
Can someone tell me if the bellhousing for a 36 Chevy 207 cu. in. ? is the same as the later 216 bellhousing ?
#60528 05/15/2006 5:10 PM
It's not the same, similar but the 216 housing is wider due increase size of flywheel. I think the bolt pattern for the transmission is the same as the truck 4 speeds were the same from 1930 to 1947.
34 & 35 trucks are the greatest
#60529 05/16/2006 3:18 PM
35 trucker, do you know if the 216/235 bellhousing will bolt into the 36 frame without modification ?
#60530 05/17/2006 9:27 PM
I don't know if it will. The engine block length is different between the 207 and the 216 blocks. They use the same front mount on all trucks on both engines and the 36 uses the same two bell housing side mounts that the 32 car and the 34& 35 1/2 ton trucks do. They our basicly 90 degrees to the crossmember. The 216 mounts are different as they mount parallel to the crossmember.
