| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60527 05/15/2006 5:02 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Can someone tell me if the bellhousing for a 36 Chevy 207 cu. in. ? is the same as the later 216 bellhousing ? | | |
#60528 05/15/2006 5:10 PM | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | It's not the same, similar but the 216 housing is wider due increase size of flywheel. I think the bolt pattern for the transmission is the same as the truck 4 speeds were the same from 1930 to 1947.
34 & 35 trucks are the greatest
#60529 05/16/2006 3:18 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | 35 trucker, do you know if the 216/235 bellhousing will bolt into the 36 frame without modification ? | | |
#60530 05/17/2006 9:27 PM | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | I don't know if it will. The engine block length is different between the 207 and the 216 blocks. They use the same front mount on all trucks on both engines and the 36 uses the same two bell housing side mounts that the 32 car and the 34& 35 1/2 ton trucks do. They our basicly 90 degrees to the crossmember. The 216 mounts are different as they mount parallel to the crossmember.
