2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#605058 12/28/2009 11:17 PM
On my newly rebuilt 235 the oil pressure guage (original) pegs at idle and high RPM. I haven't scrounged up another guage yet to check against it but I was wondering if there is some kind of relief valve in the pump.The pump is brand new. I'd rather have too much than not enough.I was wondering if it is a relief valve problem could I try using my drill with screwdrier bit in the dizzy hole and run it in reverse to shake things up ? I want to avoid dropping the pan if possible. I'm lucky enough to not have any leaks now so I'm not looking to create any. thanks
Riding in the Passing Lane
You need to hook another gauge in the outlet to test it. 40-50 lbs is normal. If you have it in an older chassis that had a splash system they only went to 30 lbs.
1972 Chevy c10 Cheyenne Super
Your gauge could be bad. Did work before? I would first check the oil line to the gauge because there is no flow through the oil line could be pluged up.
Usually, if a pump relief valve is plugged, the engine will load itself down and possibly even stall at idle due to the power consumed by driving the pump. It can also blow out the gasket at the oil filter cover, if the engine is equipped with one. Try plumbing a known good-condition gauge right into the pressure port on the side of the engine. A 0-100 lb. gauge shouldn't peg out if the relief valve is working, and if it does, you definitely need to drop the pan and figure out why the valve is sticking.
