Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#6048 01/03/2002 11:44 PM
OK, I've heard in the past people talk about a 235 cyl. head with an "848" ending on it's casting # (carb. side) I've got one for a short block I'm rebuilding. What (if anything) is so special about them? Thanks.
#6049 01/03/2002 11:52 PM
Only thing I know is they were produced in 1960-1962, so I guess the last of the lot. Does that mean anything?
#6050 01/04/2002 2:21 AM
In 1956 Chevy increased the compression ratio from 7.5 to 8 to 1 and then to 8.25 to 1 in 1958 on the 235. They did this by making the combustion chamber smaller. The "848" heads were used from 1956-62. In order to maximize the performance potential of the 235, the "848" head is recommended because of these smaller chambers. Not sure if there is any real difference between the 56-57 heads and the 58-62 ones, It may just be a "marketing ploy".
#6051 01/04/2002 6:11 PM
I've got a low compression '54 head that is ready to run, and a '60 848 head that needs to be rebuilt. Would the power increase with the 848 head be worth the cost of reworking it?
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#6052 01/05/2002 1:45 AM
The factory brake HP for a 1954 235 w/glide is 125@4000rpm. A 1960 235 is 135@4000rpm.
Whats 10 HP worth to you? $300-$600 to redo the head depending on what it needs, not including porting or flow bench testing, how fast can you aford to go?
