| | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | What's the best way to remove an oil galley plug from a brand new rebuilt 235? Just got mine fired up for the first time and it's leaking bad out of the front left galley plug.I will have good access to it once I pull the radiator back out. There is no sheetmetal on the truck.I'm familiar with the method for removing freeze plugs by cocking them to the side but I'm nervous about knocking it into the block. Is there a lip behind it to prevent it from going too far in? thanks | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i haven't on a 235, but on 250's and 292's i drill a small hole and use the screw on a slide hammer. don't worry if it pulls the screw out the first time, just go in further if you have the screw attachment for the hammer or get a bigger screw. you can always switch to another attachment if you rip a bigger hole. good luck! | | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | I'm a little concerned with drilling because I don't want any fileings going into the motor. | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | just put a little bit of grease on the drill bit and it will catch the majority of the chip's . | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There is a narrow lip. You can use a small punch off center to cock it then pry or pull it out.
Drew
| | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | Got lucky! just tapped it in a little further and that tightened it up enough to stop the leak. Now I just have to start looking for a new water pump. The only leak I have is a little coming from the center shaft of the pump.Looking and sounding pretty good so far. Just have to tweak the timing and dual cabs a bit. Thanks and happy holidays | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Sometimes you can run the engine a while and the water pump leak will heal itself, too. Not often, but it's worth a try. Just don't let it leak enough to overheat. Jerry
