5 members (32Fordpuchoptop, Otto Skorzeny, Mike B, Bill Hanlon, bluechev), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#604590 12/26/2009 10:39 PM
I have an alternator with an external regulator on my 46. 12 Volts. I want to upgrade to an alternator with no external regulator. I checked the tech tips and did a search and didn't find an answer.
Does anyone have a recommendation for the type of alternator (part or model number)I should get?
And provide a wiring diagram if there is anything more than just running it to the starter.
Thanks in advance.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #604603 12/26/2009 11:35 PM
Mike,
I have enclosed a link to the Mad Electrical site where they actually list Delco part numbers and/or model years and application so the counterman can find what you want.
Single wire units work well and would require no extra wiring on your part, only taping up some unused leads.
http://www.madelectrical.com/electricaltech/delcoremy.shtml
Stuart
1 Offline
Mike, the cleanest look will be to buy 1--wire alternator ($59 from Autozone part# DL7140M). This will clean up your firewall and all you have to do is run the single wire from the alt to one side of your Amp gauge Post and take another wire from other post and run down to the starter. This is the way to go and you still have the working Amp gauge.
Jeremy
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
1 Offline
Mike, as you know i would use heavy gauge wire 10#.
I used the one wire alternator from Autozone,went my local speed shop got the brackets,and used the ten gauge wire that attached to my generator crossed it over to the batt post on my regulator and everything else worked out normally. Use a fusable link inline from the alt. to the reg.or what 37 and atomarc said.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #605296 12/29/2009 7:23 PM
Thanks everyone, I will probably do this as soo as it warms up this spring. Everything is working now,but I wanted to plan ahead.
1946 1-ton Panel
MikeE #608861 01/10/2010 8:19 PM
My 64 Chevy 230CID had been upgraded with a new model alternator. The previous owner had bypassed the voltage regulator and had a wire running to a switch (diode?) and then onto the ignition. My assumption is this was to "excite" the alternator into charging. I was having a problem with mu charging system so I went to my local electrical shop. The counter fellow suggested getting rid of the wiring and inserting a Delco 10SI S/E Reg to bypass all the wiring hocum. Bottom line the alternator needed to be replaced. When I went to Autozone we looked at the 1964 alternators and found this certainly was not the one in the truck. The closest one I found was from a 1980 Chevy part number (DL7127-9M). My question is is this considered a single wire alternator? I read the posts from Mad Electrical (and found my part number) but nothing about the need to update the alternator with this additional part. I installed the alternator, reved the engine up to 1500 rmps, but I do not see a jump in voltage to the 14.5 range. Any thoughts?
IMHO there was no single wire alternator as a OEM option or as a factory installed part.
Applying 12 volts to DA #1 should jump the charge rate up to your 14.5 or so. Your alternator sounds like a conventional three wire unit which is OK as long as you can excite DA #1 and monitor system voltage on DA #2.
A 10SI can be modified to single wire service by merely installing the correct voltage regulator. Some rebuilders will block off the DA port to indicate single wire service but that isn't always the case. Applying voltage to DA #1 with a resulting increase in charging voltage will be your iron clad test.
Stuart
Thanks Atomarc..I reread the postings from MAD electrical and have come to understand the model I have could be one wire or three wire depending on the internal voltage regulator. The single wire is made to do one thing well, recharge batteries. The example MAD gave was a simple tractor. The three wire convention is more suited to vehicle with more electronics. I think the off the shelf version I got from Autozone is a three wire. I elected to keep it that way, so I replaced the wire back to the ignition and put the jumper back to the main load connection. I put the volt meter back on the system and can see it bob up to 14.5 volts when I place a demand on the system. So I think I am okay, until I break the next thing. Say do these doors coma apart?
Best Regards,
Joe aka The Forge Dude
1 Offline
I'm changing my 53 1/2 ton to a 12v system as well on my 235ci. Jeremy, I called Autozone to get that alternator but they didn't recognize that #. Does anyone know what year and model I should be asking for? I prefer Delco remy but will go with any brand that works best. I believe Autozone only sells Duralast. Thanks
1953 3100 Chevy 5 window
1971 Chevelle SS
the local electrical shop can convert your alternator to single wire.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Hello, I looked that part number up on Autozones website and it's not listed. Can you advise for what year that part number belongs? I have a 46 1.5 ton and I'm in need of a 12v alternator.
I just told them that I needed a one-wire,they asked what year, I said does'nt matter because I'm not putting it on a vehicle that had an alternator.I'll check tomorrow to find the #.
1953 Chevy Two-Ton
PapaJ #614796 01/29/2010 8:19 PM
1953CHEVY, I believe the correct part number is
DL7127-12M this is a 63 amp alternator with the DA plug in the 12:00 position but is also three wire not one. I plan on converting my 1946 1.5 to 12v as soon as the weather warms up a bit in K.C. The three wire version isn't that big of a deal to wire up. You really only have one extra wire to run to the ignition because the short wire from the DA plug just connects to the Battery Terminal on the back of the Alternator.
