7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,428 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60441 05/14/2006 3:42 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I want to find out what my 4-speed tranny might have come out of...is there a way to tell how many grooves are on the spline without pulling tranny? I have checked over at Inliners but they don't list it.
casting number is 3935656...there are some other cast numbers too: on a raised stamp is 8054...next to that is an unusual letter combo that looks like an N and F together followed by 01
any help is appreciated!
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#60442 05/16/2006 12:14 AM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I know it was the weekend...so I thought I would bump this up again to see if anyone can help!
Blue 50
#60443 05/16/2006 4:15 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I'll bet Patrick's could tell you from the number.
Mike Barnes 1950 GMC 1-ton pickup
#60444 05/16/2006 9:35 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Mike, your probally right...he must have seen hundreds of them!
Blue 50
#60445 05/19/2006 8:02 PM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | Blue - Out of curiosity was Patrick able to ID your tranny for you? I have the Sag 4spd 2- Ring tranny he recommends but after many e-net searches and trips to the bookstore I've never been able to positivly ID my transmission. About all I know is it's GM. One clue I did read was that the lower first gear trannys were used on 6's and the higher ones were used on V-8's. Bug
1951 Chevrolet 3100 AD Pickup
