| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60434 05/14/2006 4:38 AM | Joined: Mar 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 70 | Am selling my 54 235 to a guy in Oregon and was taking a closer look at the engine and noticed the little washer with lead like substance in the center that the rebuilders intall on a freeze plug for warranty puposes to see if you have overheated engine, ??? when did they start using those. Would like to let Chris know for more info on the engine. Thanks for any input in advance. | | |
#60435 05/15/2006 6:31 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I saw them on Jasper engines in the eighties, so it's been a while. | | |
#60436 05/15/2006 8:01 PM | Joined: Mar 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 70 | Ya, I had seen them in the late eighties but wasnt sure if they used them in the seventies or sixties, a rebuild in the eighties is better than an original 54 motor in my opinion, when you consider the use in the last decade then it would be a low miles engine. Thanks for your input!!! | | |
#60437 05/19/2006 2:33 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | The heat tabs are still used in the industry but the latest technology is a sticker.It serves the same purpose but instead of melting at 260 degrees they turn red.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
