0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60415 05/13/2006 2:04 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Just a note for those lucky enough to have a 261 engine to power there ride. It seems that some of the FLAPS out there list the oil pumps for these motor as fitting all yrs. This a incorrect. If you have one made in 54-55 it takes the same pump as a 235 for 53-54. There are at least 6 differnt pumps listed for this motor but only one is the right length. Make sure and compare your old one to the new one so that you get excatly the right one and not just one that fits the engine. It makes a big differance on the depth it goes down into the oil screen. I dont know about the other yrs for the 261 but if you get a slightly wrong pump your going to be very unhappy, very quickly. | | |
#60416 05/13/2006 8:36 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I had a hard time finding the correct replacement oil pick up tube and screen- Ended up finding it NOS from Obsolete Chevy, but it was expensive.
