2 members (porsche, Dennys28),
93
Mod | | | Forums66 Topics128,051 Posts1,055,766 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 16 Apprentice | | Apprentice Joined: Mar 2003 Posts: 16 | ok guys i am getting back on a old project. i can't find any timing marks on the cam gear. i found the "0" on the crank gear but nuthin on the cam. it is a fiber cam gear which from what i understand was only used in cars. should i get a new gear? metal? hopefully it will have a timing mark on it also do you guys degree your cams? i have done it on mercedes V8's and find it worth it but is it on a old bolter. thanks | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Worth it on any engine if a person wants to take the time to do it. Get the metal gears, they will have the marks on them.
