2 members (Tinker5, klhansen),
121
Mod | | | Forums66 Topics128,193 Posts1,057,256 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 2 New Guy | | New Guy Joined: Feb 2009 Posts: 2 | I want to upgrade my 58 Apache front suspension with coil springs, disk brakes and power steering, also want to change the rear end ratio for a V-8 with a 700R4. Can anyone answer a few questions for me, the first, has anyone used a 1973 to 1987 C10 frame under a Task Force short wheel base truck? The second, would a 1998-2004 S-10 Blazer frame work better? I can obtain the C10 from a salvage yard alot cheaper than an IFS would cost me, which an IFS is about $3000.00 Please let me know. I appreciate your help. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Never done it myself but I believe the S-10 frame is much closer to the Apache frame you have. The C10 is way too big. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The S10 Blazer frame will be too narrow, plus too short on the wheelbase (100" wheelbase for 2 door, 107" for 4 door). Try a search on the site. There's a few guys on here that are adapting the front crossmember from a C10 truck to the '55-'59 chassis.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 16 New Guy | | New Guy Joined: Apr 2009 Posts: 16 | | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | S-10 is really, really narrow. You have to run 2" spacers on an AD, and the TF is about 5" wider yet.
The 73-87 IFS would need to be widened just a bit (or your frame pinched)
I would look into a Corvette IFS and IRS or a Jag unit before spending $3000 on an IFS kit. I also bet that IFS kit is Pinto based as well.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Bob, that is one of the cleanest clip jobs I have seen. Did you also use fish plates inside the box section, or did you but weld it?
| | | | | Joined: Dec 2006 Posts: 7 New Guy | | New Guy Joined: Dec 2006 Posts: 7 | I agree with Bob,it's takes a little work,but the camaro-firebird clip is the way to go.I did mine with a 1979 firebird trans-am big-block and now have p.s,disc brakes,and real beafy front stabilizer bar.Used a 1997 pontiac firebird trans-am rear[flipped on top the springs] in the rear and now have disc brakes and a 3:42 posi ratio and the trans-am rear stabilizer bar.
Arch5807
| | | | | Joined: Feb 2009 Posts: 2 New Guy | | New Guy Joined: Feb 2009 Posts: 2 | I want to thank each one for their reply, Midget Farmer, LongBox55, THilde, Scott Danforth, Bob B and Arch5867. You all make the rebuild much easier, by responding to my questions and providing me with all of the threads and links. I appreciate all of your help. THANKS STOVEBOLTERS | | |
