4 members (Otto Skorzeny, Steelonsteel, Woodcmiami, Millenimech), 84 guests, and 2 robots.
Topics128,050
Posts1,055,760
#6039 07/17/2003 4:39 AM
Apprentice
Apprentice
ok guys i am getting back on a old project. i can't find any timing marks on the cam gear. i found the "0" on the crank gear but nuthin on the cam. it is a fiber cam gear which from what i understand was only used in cars. should i get a new gear? metal? hopefully it will have a timing mark on it
also do you guys degree your cams? i have done it on mercedes V8's and find it worth it but is it on a old bolter.
thanks
#6040 07/17/2003 5:07 AM
Worth it on any engine if a person wants to take the time to do it. Get the metal gears, they will have the marks on them.
