| | | Forums66 Topics128,186 Posts1,057,324 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | My bolts (connect brake line to wheel cylinder) have some minor rust in them. Should i just rerust them and use them again, or should i replace them? Are they supposed to have a special rust proof coating (ie, brass or stainless)? Thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Called "Tube nuts" You can get new steel ones at most any auto parts store. Stainless ones can be had but take some looking (PM me, I probably have some)
But to replace them you'll need to re-flare the brake lines, and if you do that you may as well make new brake lines if your old ones are very old.
Short answer is if the brake lines are OK and the tube nuts are reusable then reuse both. If either are due for replacement then replace both the lines and use new tube nuts.
Grigg | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Thanks for the quick reply. I just installed new brake lines so i'll probably get new tube nuts as well. | | |
