5 members (Phak1, tclederman, Charles in CA, wvstovebolt, 1 invisible), 210 guests, and 4 robots.
Topics128,083
Posts1,055,967
Members48,430
#602322 12/18/2009 2:33 PM
1950 3100 3 speed column shifter rebuild:
During assembly does the internal shift arm spring take one complete turn on the shaft for arm tension or less? My spring had slipped off the shift arm ear and uncoiled thus the need to rebuild. Sure isn't many moving parts inside,but I want to make sure I don't over tension the spring.
Drew
I'd like the correct answer to this one, also. These shifter boxes seem so simple, but it appears that the settings and clearances are critical. I put the spring on with one turn, and latched the straight end around the "dog" that moves in between the gates. This place tension on both shifter arms. However, I'm not certain that it is on correctly. It's working reasonably well. Does anyone have any closeup pics of this box inside? The one picture I have found in a manual is very difficult to make out how the spring is set.
Well, I will have pics of reassembly, but the before pics just show the dislodged spring and lots of grease. smile So, that still doesn't help with our question. And, with one turn it seems like it will operatye just fine, but I'd like to be sure.
Drew
The first turn that catches the "dog" is how I have mine, and it works all right. I think that is correct. No pics, yet? From anybody?
Okay here are some pics. Anybody know if the spring is mounted correctly or is even all there? The ones with grease is how I found the assembly after opening the shifter box.
http://pic100.picturetrail.com/VOL1061/3611363/16876743/380000803.jpg
http://pic100.picturetrail.com/VOL1061/3611363/16876743/380000804.jpg
http://pic100.picturetrail.com/VOL1061/3611363/16876743/380000808.jpg
Drew
Thanks, good pics. That's how the spring is on my box-'55 1st series.
Can you repost pictures?
A notice pops up that says your pics have been deleted.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Those pictures were posted here in 2009 by the OP and he hasn't been here since 2016, so my guess is those pictures are gone forever...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
