3 members (Bill Hanlon, Gdads51, Otto Skorzeny), 138 guests, and 3 robots.
Topics128,164
Posts1,056,982
Members48,458
#6033 04/30/2002 2:38 PM
I
I Offline
I'm back, 1942 dump truck.
Where do i find out what the truck is? No glove box so no id. I'm assuming 1.5 ton?
Also, I have no brakes, the front rubber lines are gone. Any parts shop suggestions or just try and match up?
On the rear, dual wheels, do i have to pull the axles or is the drum seperate?
Any help on maybe buying parts? Not looking to resotre, just looking to use on the farm so just a little brake would be nice smile
I
I Offline
ttt
If it has 136-1/2inch wheelbase, it started life as a 1-1/2 ton, but with those massive plates on the chassis rails could have been uprated. Also look for heavier front axle as used on Canadian Maple Leaf trucks.
OLD 42 smile
' Offline
IWL BCNU,
Your VIN plate should be on the right side of the cowl, under the hood. It should start with a single or two-digit number, followed by a two-letter identifier (that could be MR--134.5" or MS--160"). If your VIN plate is there, you should be able to break the code using the Art Deco Site (a link off The Stovebolt Page).
Parts places' links are also here. Jim Carter, Chevs of the 40's, etc might have what you need.
Regards,
A great lady, a stovebolt, & a small town! What else is there?
Aspiring '54 6400 dump truck owner
'Bolt On
IWLBCNU,
Dunno y I wrote 136.5". Should of course be 134.5" for 1.5 ton. With age comes wisdom, (and wrinkles), (and alka selzer).
OLD 42 :confused: :confused: :confused: :confused:
I
I Offline
Found the title, he bought it in 71 and the CO-OP bought it in 59.
As for numbers, 21049 1 1/2t
345150 42 ew 7500 gw 13500 is on the title. I understand the simple parts smile
