5 members (lumbersawyer, MickeyP, greenie-reddy, 68ironhead, moparguy), 54 guests, and 3 robots.
Topics128,175
Posts1,057,119
Members48,463
JC
Offline
Hi All,
How difficult would it be to swap a disc brake setup from a 76 Chevy 3/4 van to a 66 Chevy C20?
I've seen topics on using 70s c20 pickup front brakes, but do the Vans use the same parts?
Any input in welcome.
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
I parted out a '74 G20 van a few years ago. It appeared the front suspension was similar in design to the pickups, just a bit wider.
However, some 20 series vans had 5-lug hubs and some have 8-lug, while your '66 C20 is 8-lug. I'd start by making sure the van has the number of studs you require.
You might be able to swap spindles using newer ball joints. But I don't know the particulars of this swap. HTH!
JC
Offline
Thanks for the input. My 76 G20 Van has the 8 lug studs
JC in KC
