| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 17 Apprentice | | Apprentice Joined: Mar 2009 Posts: 17 | I recently bought a '49 3600, with original parts, including the engine. The engine has the (apparently common) 'babbit rod knock' and recently started burning oil.
I'm a newbie, not mechanically savvy, and am torn between replacing it with a 235 or having it rebuilt.
The engine only has 43,000 miles on it and the rest of the truck is in very good shape. I'm weighing the pro's and con's of a 'numbers matching' truck with a stronger/more reliable engine. Any advice?
Lastly, what would one expect to pay for a good rebuild of the 216 or for a reliable (rebuilt) 235? Is there a significant value difference for 'numbers matching' if I restore the truck? Thank you in advance for any help.
Life's cruel to shiny things
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | +/- $3000 to rebuild 216. Under $500 for used 235, whether it's good or not, who knows, bout the same to rebuild it. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If the 216 only has 43K miles on it you likely don't need a major rebuild unless it was mistreated. Burning oil could be something as simple as valve seals or more severe like broken piston rings. Check the compression on all cylinders first and see how even they match to each cylinder. You may just need the cylinder head reconditioned. That price can vary between machine shops, but could be several hundred bucks, but way cheaper then a complete engine rebuild.
Drew
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I can't see putting money into a dead horse.The rebuilding cost is bull [censored].Is richard peddy doing the build.Just sold a 54 235 for $100 + tranny.rebuilt with 3100mi.Let's be fare.216 low oil pressure.Only driving too church on sunday????
dan-pa
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think that everyone has a different definition of what a "overhaul" is and a "rebuild" is. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Rebuild to me means vat/flux block and head, replace all parts as needed. Getting ready to begin putting my 235 together that I swapped for the original 216 babitt poured bearing smoker beast. Drank more oil than the gas it used. My cost including new crank, pistons, cam and machine shop work is right @ $2500.00. If you are going to make a trailer queen show piece out of it to sell then worry about #'s matching. It's a truck not a 'Vette...I want to drive it, heck I want to drive that 'Vette too!
Hank | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | From what I have seen, a well done 235 replacement is a respected upgrade to these trucks. I don't think "numbers matching" is something that is considered with these AD trucks. With auctions like Barrett Jackson, the upgrade seems to bring more money than the original. | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | are you sure the odometer hasn't rolled over? maybe 143,000?
I love the idea of keeping and original truck original....but it does take some coin.
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Mar 2009 Posts: 17 Apprentice | | Apprentice Joined: Mar 2009 Posts: 17 | Thanks guys - I really appreciate the feedback.
I'll determine if a modest investment will get the 216 running 'smoke free' - if not I'll find a solid 235.
Thanks again.
