4 members (Southerntruck, Hotrod Lincoln, 52Carl, TUTS 59), 92 guests, and 1 robot.
Topics128,162
Posts1,056,932
Members48,458
1951 GMC 3/4 ton
I need some opinions for shocks.
KYB gas-adjusts are too stiff for this application. I'm looking for good control with out my teeth clicking on every pebble on the road.
thanks!
jimmy
Last edited by Woogeroo; 12/21/2009 7:35 PM. Reason: added year & model to the subject line
Try here, the cheaper shocks should be much softer. Cheap ones are the first in line and the better grades follow.
http://www.monroe.com/catalog/documents/08_MountingLengthSheet.pdf
Joe
listen toooo the above.He's right on.Sometimes you get screwed buying these heavy duty parts.Rought ride.The truck is not on the farm anymore.Do what you got too do
dan-pa
