Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 68 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
I`ve been putting this off for too long now. The doors on my 49 GMC Cab Over Engine need new guts and and an inside lower hinge mount welded in place. So the question is... How do you take a door [b]apart?[/b]
Drill out the spotwelds? Or cut the inner panel and weld back after the inner repairs completed?
For thehinge mount you will probably have to do some cutting. The rest of the door comes apart as per the manual.
1951 1 Ton Completed
