0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | can't I just use my original clutch and pressure plate from my 235 with the 3 speed when installing my t-5? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can use the pressure plate but the disc has different splines. You can get a disc made up at a clutch shop or there is a place listed in the tech tips in Springfield, Mo. that makes them. You can use one for an Astro van or Camero but they just sell complete kits anymore. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you can still get a disc separately. the counterperson more than likely isn't bright enough to look it up or to lazy; one or the other ron | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You might check on a clutch disc for an 83/84 Firebird...that's the one I'm running in my 235/T5 truck. Also have run an RCF-4201. These are 9-7/8" discs. They both will have the proper spline count and neither had to be modified. These are for an S10 T5...the Camaro uses a different input shaft with a different spline count.
Just be sure to have the rear of your splines opened up so the disc will slide past (towards the transmission) 1/4-3/8" before you install the disc/pressure plate. I've got some information on the modifications to the transmission and how to complete the install the first time in my Webshots album.
Dave | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Astro van clutch disc for the 4.3. Years are 1985 - 1989
| | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | Hey thanks for the tips guys, Dave the pictures were very helpful. I thought I understood what to do concerning the cutting and grinding of the splines but I just didn't trust myself . anyone who is considering this should take a look at Daves pictures. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Or simply use a Camaro front half and S-10 rear housing and shift cover (Hybrid). The splines are longer, the bearing retainer is shorter, and the pilot is shorter.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the 11"clutch disc that I purchased and installed was a fenco CP31078 and that was for an astro van ron | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You've just got to match the clutch disc to the pressure plate and bolt holes in your existing flywheel. I was a bit skeptical about using the 9-7/8 clutch disc in my 54 truck but it matched up with my pressure plate/flywheel bolt pattern and after 10K highway miles it's as smooth as the day I put it in.
Just a note....the Camaro input shaft has a different spline count than the S10 input shaft and if you're building up a hybrid to run behind a 235, you might have to hunt a little to match up the disc/pressure plate with the correct 235 flywheel.
Dave | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Dave, only the V8 trans has the 26 spline x 1 5/32 input shaft. The V6 and 4 cylinder transmissions all have the same 14 x 1 input shaft. If your running a ford trans, the early ones have the 10 x 1 1/8 spline and the later have the 26 x 1 5/32 spline. Jeep has yet another spline.
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Correct...just wanted to make sure that anyone considering running a hybrid T5 be aware that they might run into some problems locating a 26 spline (9 7/8") disc to bolt to a 216-235 139 tooth 6v flywheel with a 10" pressure plate bolt pattern.
The Jeep boxes have 10 splines on the input shaft.
Dave | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The 26 spline 9 7/8" disc would be from a 1996 or newer V6 camaro
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | any 14 spline 10 3/4 clutch that you can purchase over the counter without being custom made | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1982-84 Blazer 2.8 V6 9 11/16" disc #CD4201, should work fine in a 10 3/4" set-up.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | why go with the 9 11/16" when you can use the Astro Van at the right diameter.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | it makes the thread go further ron | | |
