1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
What do I need to do to get my '65 6cyl OEM (SUN) tach to work w/ my 8 cyl????
Some of the Sun tachs have a switch inside the housing to select 4, 6, or 8 cylinders. If not, you might have to find someone to do a little rewiring. The old style Sun tach with the big sending unit that resembles an oversized voltage regulator with a brown Bakelite cover would need a total rehab with modern parts to work right, since it had its own oddball Mercury battery power, and the batteries can't be found now.
