8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle),
106
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 26 | What do I need to do to get my '65 6cyl OEM (SUN) tach to work w/ my 8 cyl???? | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Some of the Sun tachs have a switch inside the housing to select 4, 6, or 8 cylinders. If not, you might have to find someone to do a little rewiring. The old style Sun tach with the big sending unit that resembles an oversized voltage regulator with a brown Bakelite cover would need a total rehab with modern parts to work right, since it had its own oddball Mercury battery power, and the batteries can't be found now. Jerry
