6 members (Bucker, moparguy, TooMany2count, 66flea, 2 invisible), 96 guests, and 2 robots.
Topics128,174
Posts1,057,049
Members48,458
I've read some threads where it was mentioned that one should not use "old" lifters with a New/Re-ground Camshaft. Are there serious consequences? I have Solid Lifters and they seem to be in Good shape. I mean Brand Spankin' New ones aren't that expensive,($85-90 for 12) but if I can use the ones I've got..Why not? Thanks!
(55 / 235)
Kato, do asearch on this subject as it was very recently discussed here with good information.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Cams and lifters wear a pattern together. If you look at service manuals, lifters must be kept in order to be be able to put them back in the same hole. It makes no difference what engine you are working on, you should never put used lifters on a new cam.
Took a look and I will be buying new lifters. Thanks 53moneypit!
Reading up on some previous posts, I came to that conclusion as well crenwelge. Thanks for the info! Been away from tinkering with engines for quite some time, so I am slowly catching up to speed and learning about stovebolts as I putter forward.
