2 members (Gdads51, moparguy),
96
Mod | | | Forums66 Topics128,180 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | I've read some threads where it was mentioned that one should not use "old" lifters with a New/Re-ground Camshaft. Are there serious consequences? I have Solid Lifters and they seem to be in Good shape. I mean Brand Spankin' New ones aren't that expensive,($85-90 for 12) but if I can use the ones I've got..Why not? Thanks! (55 / 235) | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Kato, do asearch on this subject as it was very recently discussed here with good information. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Cams and lifters wear a pattern together. If you look at service manuals, lifters must be kept in order to be be able to put them back in the same hole. It makes no difference what engine you are working on, you should never put used lifters on a new cam. | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | Took a look and I will be buying new lifters. Thanks 53moneypit! | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | Reading up on some previous posts, I came to that conclusion as well crenwelge. Thanks for the info! Been away from tinkering with engines for quite some time, so I am slowly catching up to speed and learning about stovebolts as I putter forward. | | |
