5 members (Otto Skorzeny, TUTS 59, IHPWR, Charles in CA, Millenimech), 100 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
#602312 12/18/2009 1:42 PM
i just received a pilot bearing for my 59-235 and need to give it to my builder to install for me. one end is flat and the other is beveled. my thought would be that the beveled end faces the tranny. but does it so i can pass on to the builder.
51 ashton #602323 12/18/2009 2:35 PM
yes, bevel towards trans.
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #602431 12/18/2009 10:07 PM
Pilot bearings have the taper to make stabbing the transmission easier. Its bad enough with the taper. Every time someone tells me they are having trouble stabbing a transmission, I tell them to look at the bearing before they proceed.
crenwelge #602532 12/19/2009 3:16 AM
Taper on the outside.
Outside or inside, it took me 30 years to figure out how to easily slide a transmission into place: cut off the heads of two long bolts and place the studs/stems into the top two transmission mounting holes in the clutch housing. Then lift the transmission up to the bolts and slide the transmission home (rotating the main shaft as needed to mate the splines on the front shat into the clutch). This procedure makes this job a cake walk - taper on the outside or on the inside.
This technique makes the installation of even an SM420 an easy one-person (plus a cheap-jack) job.
tclederman #602549 12/19/2009 3:51 AM
Many years ago when I worked on school busses, I had a winch rigged to go through the side door to lift the transmission and rotate it out of the way. Romoving the floor pan above it made it easy access.
Little harder when having to do the work under the truck, but the bolt idea works very well.
