1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i have a 69 front end going in my 59 my queston being can later model spindles be used inplace of the 69's "might wanna run disk brakes later" far as i can tell info wise which not alot of it out there for this they are the same except for the shaft of the spindle holding the wheel bearings
1937 1/2 ton
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The can be used, but you have to swap over to balljoints for the later truck. I beleive the tie rods are different, too. '73-'87 is the year range you'll need.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 33 | You can also use 71-72 spindles that were for disk brakes. I have converted a few 67-70 pickups to disk brakes that way. | | |
