5 members (68ironhead, Gdads51, TrknGMC, 53 green 1- ton, msmall), 168 guests, and 3 robots.
Topics128,086
Posts1,056,094
Members48,434
#60149 05/07/2006 3:37 PM
1 Offline
hello all,
I'm just gitting started on a 1947 1st (almost the same as a 46) I could not get it turn over. so my ?? is do i rebild or swop? I'm thinking about doing a swop with eather a 250 or 292.
How long has it been since it ran? If it has been a long time you might want clean it out a bit before deciding.There are several previous posts about freeing up an engine with various oils and solvents. I would consider doing this even though you can get it to spin, just to get the crud broken up and everything lubricated. When it seems to spin freely, do a compression check to see where you are before you decide.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
#60151 05/08/2006 12:18 AM
1 Offline
I'm Gessing it has been over 8yr of not more. I can get it to turn wen I pull it or wen I put 12v to the starter. One thing that makes Me leed to just doing a swop is I'm not doing a restration job I'm "hotroding" it to some exstent. and I would rather put preformance parts on a 250 or 292.
That's as good an excuse as any. Yank that thing out and do what you REALLY want to do. I say go for it and have fun. Ya got any pictures you want to share?
1 Offline
I Dont have them on my pc at this time but i will soon. steppenwood you got pictures?
1 Offline
steppenwood- Your truck looks grate do you have pictures of your work? any advise?
