9 members (Steelonsteel, 55shaker, GRNHydra, WICruiser, 51sub, Wally / Montana, Peggy M, Hotrod Lincoln, 1 invisible),
108
Mod | | | Forums66 Topics128,141 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60149 05/07/2006 3:37 PM | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | hello all, I'm just gitting started on a 1947 1st (almost the same as a 46) I could not get it turn over. so my ?? is do i rebild or swop? I'm thinking about doing a swop with eather a 250 or 292. | | |
#60150 05/07/2006 8:59 PM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | How long has it been since it ran? If it has been a long time you might want clean it out a bit before deciding.There are several previous posts about freeing up an engine with various oils and solvents. I would consider doing this even though you can get it to spin, just to get the crud broken up and everything lubricated. When it seems to spin freely, do a compression check to see where you are before you decide.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
#60151 05/08/2006 12:18 AM | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | I'm Gessing it has been over 8yr of not more. I can get it to turn wen I pull it or wen I put 12v to the starter. One thing that makes Me leed to just doing a swop is I'm not doing a restration job I'm "hotroding" it to some exstent. and I would rather put preformance parts on a 250 or 292. | | |
#60152 05/08/2006 3:08 AM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | That's as good an excuse as any. Yank that thing out and do what you REALLY want to do. I say go for it and have fun. Ya got any pictures you want to share? | | |
#60153 05/09/2006 1:19 AM | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | I Dont have them on my pc at this time but i will soon. steppenwood you got pictures? | | |
#60154 05/09/2006 1:29 AM | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | steppenwood- Your truck looks grate do you have pictures of your work? any advise? | | |
