| | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60133 05/06/2006 10:26 PM | Joined: Mar 2006 Posts: 12 Junior Member | | Junior Member Joined: Mar 2006 Posts: 12 | I pulled the engine out of my truck today and want to install a new front seal and rear main seal. It is a 250 six cylinder. Couple of questions. I know the harmonic balancer must be removed with a puller, but how do I re-install it? I thought I could thread a bolt into the end of the crank and pull it back onto the crank with the bolt, but the crank does not have a threaded hole in the end. So, how do you re-install a harmonic balancer? Second, are there any tricks to installing the rear seal? Will it be necessary to remove the rear main cap and loosen all other main caps so I can pull the crank away from the block a little? Or, can the top half of the seal usually be removed and replaced without loosening all main caps? Is the rear seal a real bear of a job? What have I gotten myself into? Tim | | |
#60134 05/07/2006 3:55 AM | Joined: Aug 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 51 | Tim, Check out the Tech Tips under engines for rear oil seal replacement. Did mine with no problem. Never did the front one so can't give you my two cents.
1965 C-10 Stepside
#60135 05/07/2006 3:17 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can install the balancer with a heavy drift & a large hammer. Clean the surfaces real good & use some rtv sealer on the balancer. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
